Gpm of a 2030
right said fred
04-24-2002 23:04:04
Can anyone tell me the gallon per minute of a late model 2030 at the remotes?
SmallOps
04-25-2002 02:08:24
 Re: gpm of a 2030 in reply to right said fred, 04-24-2002 23:04:04
Measured at the SCV: At 2100 RPM, Hydraulic oil warmed to 120-140 degrees, tester adjusted to 2000 psi - flow rate is 5.50 to 6.50 gpm.
Measured at the remote cylinder: Using a 2.5 x 8 inch remote cylinder (and same testing conditions as above) - flow rate 5.50 to 6.50 gpm... (of course)... and the cylinder extension time will be 1.5 to 2.0 seconds.
Both tests are from the TM-1051 manual.
