Help 60-0 having snow plowing trouble and leaky head gasket
Rob
12-30-2001 21:13:41
just ground the valves and top of head on our 60-0 put back together and torked head to 150 and it seems to run great so i put the snow plow on it for the fisrt time in about 3 years we have this crude thing that bolts to the frame and seems like soon as it got hot the antifreez started runnin out of the top of the gasket but befor i let the tractor run for like 4 hours very fast with just water and no leaks help
Phil
12-31-2001 07:50:43
 Re: Help 60-0 having snow plowing trouble and leaky head gasket in reply to Rob , 12-30-2001 21:13:41
The 60 head gaskets are almost like a box of chocolates these days, you never know what you're going to get. The best gasket available from Deere today is the rubberized black one, which is hit or miss whether you get it or not via will call order. We have overhauled several "60" tractors in the last few years, complete with decked head / block to ensure sealing, some of which do & some of which don't. (Only leak under load) One trick that can help is to replace all of studs/nuts when engine is down. Many of these tractors have been apart numerous times, torqued, re-torqued, etc. and have too much stretch in the studs, creating un-even torque across the face. You may try using a smidge of high-tack, especially along the upper edge.
