720 Pony Motor Camshaft
Rob
11-15-2001 11:26:11
Any body have or know where i can get a good used or prefferibly new camshaft for one of these little motors?
Thanks
G Taylor
11-15-2001 23:10:35
 Re: 720 Pony Motor Camshaft in reply to Rob, 11-15-2001 11:26:11
Most quality engine rebuilding shops have connections with cam grinding shops. The old cam is welded up if required & machined true. It was cheaper to do this with our 70D than purchase a used cam. Surface hardening is performed if necessary. Either use new lifters or have them re-surfaced in the same shop. New sleeves for pup engines are available to reduce the "blue" starting cloud. Replace the pup coolant pump seals as well. A classic place to allow coolant leaks into ruin the rods.
Frank-in-Tallahassee
11-16-2001 05:21:06
 Re: Re: 720 Pony Motor Camshaft in reply to G Taylor , 11-15-2001 23:10:35
Good point, but if you renew the pony water pump seals, check the shaft for pitting...it is no longer available, but Greg Stephens does reproduce them.
Been there done that !
70D // 855
