John Deere 970
Tom Hoffman
08-21-2001 12:46:03
I have a 970 and after using the clutch a lot while using the loader, the clutch doesn't want to release when I shift. Is there a lubrication point I missed or why does it do that?
George Benedetti
02-20-2004 04:38:27
 Re: John Deere 970 in reply to Tom Hoffman, 08-21-2001 12:46:03
Tom, I am about to buy a 1999 John Deere 970. What have you learned about your clutch problem? Thanks. George
Mike Andersen
11-18-2006 05:58:34
 Re: Re: John Deere 970 in reply to George Benedetti, 02-20-2004 04:38:27
I also have a JD 970 and experiencing the same problem with the clutch in four wheel drive. I am not totally convinced that it is a clutch problem, as I have noticed that when I raise the front wheels by applying down pressure, they rotate, which tells me that they were in a bind. I'm wondering if JD mismatched the tire size, creating an improper ratio between front and rear differentials.
carol shepardson
11-11-2006 20:56:49
I'm thinking of buying a 1999 970 john deere and wonder what clutch problem you're having and if you are having any other problems
