Timing on d
rob australia
07-25-2001 21:27:56
this is my first 2 banger . it had the maggie pulled of it all i want to know is how to set it up again. and which cylinder is no 1.left or right.i have books on the old poppers but no manuals. thanks rob.
Theman
07-26-2001 10:19:28
 Re: timing on d in reply to rob australia, 07-25-2001 21:27:56
There should be cast writing on your flywheel to indicate when the mag impulse should trip. The writing on my flywheel says "L.H. Retard Spark" There is a mark on the bearing cover on the side of the transmission case you can see while reading the writing on the flywheel. You should hear the impulse snap when rolling the flywheel forward and the marks line up. The #1 (flywheel side) plug should be the one to fire. Switch the wires if the right plug fires. I can email pictures of this on my '30 D if you wish.
Gpower
07-26-2001 08:21:19
#1 is on the flywheel side
