4020 power
rob australia
09-14-2000 05:43:09
hi all.
could any one tell me if running a strait pipe
out of the manifold cause loss of power or damage
to the engine .
regards rob.
Kerry Miller
09-15-2000 08:24:46
 Re: 4020 power in reply to rob australia, 09-14-2000 05:43:09
I don't think you'll hurt the vavles if the pipe isn't very short. If it makes it out the top of the cowl it's probably fine. The problem with short stacks is that the valves cool too rapidly, causing them to warp.
Frank
09-14-2000 17:35:21
I worked on a farm when I was in high school. They had two 4020's. Neither one had a muffler They were in use constantly and never had a problem.
Greg H.
09-14-2000 07:05:35
I don't think It would contribute to a loss of power. When I pull my 4020 I usually run a straight pipe, in hopes of it running a little more free. I have heard people say that if you run a straight pipe all the time, that it might not be good for the valve train, and that alittle back pressure is a good thing, however, I'm not for sure on that. A straight pipe I think increases power, but even if it doesn't it sure makes them sound mean. Good luck with your tractor. Greg H.
TB SCOTT
09-14-2000 09:39:21
 Re: Re: 4020 power in reply to Greg H., 09-14-2000 07:05:35
I ALWAYS GOT A KICK OUT OF PEOPLE WHO SAID THAT THE MUFFLER "CUSHIONS" THE VALVES....COME ON, THINK ABOUT IT. AT THE SPEED THE VALVES MOVE IT DOESN'T MATTER WHAT KIND OF PIPE IS ON IT. ANOTHER MYTH IS YOU'LL BURN THE VALVES WITH A STRAIGHT PIPE...HOW I DON'T KNOW, THE EXHAUST TEMPERATURE IS ALL THE SAME COMING OUT OF THE HEAD. THE ONLY THING A STRAIGHT PIPE WILL HURT IS YOUR HEARING...
Pat
09-15-2000 08:47:36
 Re: Re: Re: 4020 power in reply to TB SCOTT, 09-14-2000 09:39:21
The only thing I would worry about is chilling an exhaust valve on shutdown if the pipe is extremely short. This might lead to a warped valve, which might burn. I believe this may be a holdover from airplane engines, where you try to keep the exhaust system as light and short as possible. By the time any air goes back through a cast iron exhaust manifold, I doubt it would be cold enough to do any harm.
