Square tube wide front
Rikc
05-28-2000 07:06:06
I have a JD 520 with a square wide front and i need to adjust it, it is stuck solid. Is there an easy way to free it up. I have been squirting kroil on it for 2 months now but it still wont budge
Rikc
ben
05-30-2000 19:10:09
 Re: square tube wide front in reply to Rikc, 05-28-2000 07:06:06
i just adjusted the front on a 420 if you don't remove the bolt in the center pivoit and both out side bolts you will never move it ben
clooney
05-28-2000 08:02:22
Rikc, those wide front-ends can be a pain if they haven't been moved in a while. If you can get one side out you can put a big pipe in from that side & try to drive the other side out. The best luck I have had is putting a round rod in one of the bolt holes in the round tube, then putting a pipe over that rod, then using heat & penetrating oil on the axle I work the round tube in a twisting motion while having someone drive it out with a pipe from the other side. The good news is that if you are persistant enough it will come out, I have never had one I can't get out, but had a few I was starting to wonder about.
