John Deere LA CLUTCH UPDATE !!!!
riggsjr
08-03-2009 05:23:48
Here was my issue.....My clutch will disengage when not running and I can see the clutch disk is away from the flywheel and pressure plate,But if the engine is running than I have the problem of disengaging the clutch disk so I can shift it into gear.....The propeller shaft will keep spinning.
After changing out the pressure plate and clutch disk there was still no difference.I thought It I might of had a warped pressure plate or disk as I know I had to take it off to do the engine job and it can go back in 3 different positions but that was not it, as I still had the same problem..... I drained the clutch housing and filled that with oil.I refilled with 85/140 gear oil. I drained the transmission....Well a lot of water and very little oil came out.I refilled with 85/140 gear oil. Started her up and disengaged the clutch and behold she almost slowed down to a stop.I put by hand on the propeller shaft and stopped her.She was not moving fast at all.Adding the oil in the trans gave it just enough to slow her down to engage her.The shaft does spin a little but lets me engage the trans in 1st and than I can shift into any gear.
