Broken pushrod on 4020 d
rob
04-16-2000 15:32:00
My 4020 with turbo has a broken pushrod on #3 intake valve. The tractor was under load when it happened and started throwing smoke with a power loss. The tractor had all new rockers and shaft put on 500 hrs ago by jd mechanic. The top of the pushrod broke off and was squeezed off to the side of the rocker. It looks like an easy fix but what would cause this as I want to fix the problem not do a band-aid job.
mike
04-18-2000 06:27:39
 Re: broken pushrod on 4020 d in reply to rob, 04-16-2000 15:32:00
that's not uncommon for the end to come off those pushrods, i've replaced several on my 5020 over the years
twopop
04-17-2000 21:42:13
Probably the intake valve stuck at some point.replace the pushrod,adjust the valve to .028 and go back to work.
