What size plow with 3020 JD 70HP Diesel?
Tractorquestions
03-30-2008 21:06:01
I"ve had older Farmalls and just bought a JD 3020. I"d like to know what size plow it will pull. I know it depends on the soil, etc., but this is a 70 HP diesel, and I can"t find a source that matches John Deere tractors with equipment. Anybody out there can tell me 3, 4, or 5 bottom?
M w J
03-31-2008 13:46:14
 Re: What size plow with 3020 JD 70HP Diesel? in reply to Tractorquestions, 03-30-2008 21:06:01
Our 3020 power shift pulled 4/14s in good black soil between 3rd and 4th gear for years. When we plowed alfalfa it had root cutters on landslides and pulled in 2nd and 3rd 15/5/38 tires 4 sets wheel weight on light wheels no fluid. This was a pull plow semimount you would need lots of front weight.
msb
03-31-2008 06:15:03
4-16s in most of Indiana is right.
buickanddeere
03-31-2008 05:24:20
3X16 will stop a 70HP tractor in blue clay unless over ballasted. 4x16 is fine in sandy loam. What kind/condition of tires and how much ballast? Is the plough drawn or semi-mounted? Has the tractor been dynoed to know it's actual output? A 2WD tractor with bias tires pulling a draft load should weight between 7700-9400lbs. More ballast than what is required uses fuel to carry the weight instead of pulling the plough.
HeyPigFarmer
03-31-2008 05:08:42
With our '67 3020 we pull 3-16's. We used to have a set of 4-14's that we used on my grandparents blow sand but it would never pull them in heavy ground. Sometimes the 3-16's would give it the fight of it's life on the river flats but that is thick, heavy, nasty clay.
Handsome Jim
03-31-2008 04:13:33
I would agree with Tom, a 3020 is a three plow tractor in tough conditions.
Tom 43
03-30-2008 23:44:14
We pulled 3 sixteen steerable plow and it worked great.
thurlow
03-30-2008 21:14:52
As you said, it depends..... ....we pulled 4 bottom with 3010 and 5 and 6 bottom with 4020; all 14 inch.
