87 2250 jd
rls
02-28-2008 07:40:24
help,i have a 1987 grey market 2250 the wiring is cut up all over and have a couple switches missing needing a wiring diagam , went to dealer but there diagram color codes and set up is defernt
rls
02-28-2008 20:22:04
 Re: 87 2250 jd in reply to rls, 02-28-2008 07:40:24
thanks for the numbers buickanddeere my dealer says this tractor doesnt exziste and they have no info on it, yea went over it real good when i got it changed all fluids and filters replaced alot of stuff just trying to put wiring harness back to original status and get lights working,yes it says syncro on side of tractor the shifters between legs lft is hi lo rev rt side is 1-4 shifters comes out top of trans
buickanddeere
02-28-2008 19:40:00
AL58760 Dash WIRING HARNESS sealed beam
AL64782 WIRING HARNESS AL71084
AL70021 WIRING HARNESS (SUB FOR AL68622, AL70308)
One of those wiring harnesses should be identical or the approved replacement. May depend if it's syncro range or collar shift.
One of the long standing rural legends in there with "detergent oil blowing engines that have in the past only used non detergent oil". And that "engines require back pressure".
Is a story started by irate US dealers, tired of being undercut with cheap imported Canadian tractors/equipment. This occurred during the 1980's through to 2006 or so. Back then then the weak Canadian dollar which was worth only 63 to 90 cents US. There were many loads of purely male bovine fertilizer spread that Canadian/European JD's were grey market orphans without parts support in the US.
North American production of JD utility tractors was always split between Dubuque Iowa and Mannheim Germany. By midway through the 40 series and the entire 50 & 55 series. Utility tractors were built only in Mannheim.
Your 2250 is the real deal. I have to wonder what other items may have fallen prey to the same wire cutter. This would be a good time to analyze the engine oil, coolant and transmission/hydraulic oil.
If the coolant was never changed the sleeves maybe getting pitted. If some tinkerer added sae 90 gear lube or an economy hydraulic oil that is not wet clutch compatible. That tractor might become expensive.
buickanddeere
02-28-2008 08:50:33
Item#4 part # AL70021 WIRING HARNESS 1 serial number 769020+
There are various wiring harnesses depending or if it's a European tractor or North American, sound guard body, open station etc.
>Link
>Link Grey Market 2250???
What happened to motivate somebody to leave the wiring harness in it's present condition?
rls
02-28-2008 18:03:07
 Re: 87 2250 jd in reply to buickanddeere, 02-28-2008 08:50:33
it is european made in germany open statoin 2 wheel drive , serial#lo2250g604597, great tractor im like you dont understand some people thery of fixing somthing by cutting wires
