John Deere 5103 Electrical problem Head lights
Rob Ready
02-25-2008 08:59:51
Electrical Prblem on a John Deere 5103 160 hrs.
Instrument Panel switch that controls the headlights, low, high beam, four way flashers. Stopped working yesterday. I replaced all of the 10, 20, 30 amp fuses. The left/right turn signal operates fine. The relays were pulled out and cleaned. Still no power to the light switch which controls the head lights and four way flasher.
My other instruments work, fuel, temp guage. Any ideas what to look for ?
608-527-3287 New Glarus WI
James Tabor
02-25-2008 12:22:20
 Re: John Deere 5103 Electrical problem Head lights in reply to Rob Ready, 02-25-2008 08:59:51
I have a 5105 with 102 hours. My turn signals quit working at about 70 hours. Gone through everything. All I can figure is the switch is bad somehow. Good luck.
Rob Ready
02-25-2008 13:53:58
 Re: John Deere 5103 Electrical problem Head lights in reply to James Tabor, 02-25-2008 12:22:20
James,
I found a female connection prong that was loose. The female connection prong connects to the actual headlight switch. The switch it self was a bit loose. So each time that I would turn on the head light switch. The entire switch assembly would move just a litte. It moved enough to work one of the female connection prongs loose on the back side of the actual switch it's self.
Thanks for the response.
