PIC: JD 30 combine 4020 in 2nd crop Saybeans
1 Dollar
11-25-2007 18:20:25
third party image
third party image
third party image
Here is my 1958 7-foot 30 combine and grandpa's 1967 4020. Running double-crop soybeans with the wheat straw near Lafayette, IN. This was about a month ago but I finally got aroung to plugging it into the computer.
The first grain sample (pictured) wasn't too bad at all but it continually got worse after that. I closed the bottom sieve gradually every time I dumped until the tailings clogged up but I kept getting more unthreashed pods. I guess the beans were just getting tougher? Started around 3:30 and finished about 5-6 PM with about 1 hour of light left abd had done roughly 5 acres. New rasp bars, about half of the smaller belts and possibly a few bearings are in order before we run it next time.
Sorry on the limited pictures, I was a 1-man photography & driver crew that day.
Thanks for looking
buck eye al
11-26-2007 14:07:47
 Re: PIC: JD 30 combine 4020 in 2nd crop Saybeans in reply to 1 Dollar, 11-25-2007 18:20:25
Lots of those pods look like open pods so threshing was OK, just separating was down a bit.
You mention they got progressively worse as the day went on. Were maybe the fan house screens getting covered? The 30 & the 12A's both did that a lot. I usually knocked chaff off of those screens every time I unloaded.
Many times dropping the adjustable plate at the tailings auger (under the chaffer extension) & adjusting the wind board a bit more towards the back helped blow those open pods out the back.
Ran both the 12A & the 30 for many many years but never with so nice a tractor as a 4020. I was using A's, B's! Was like heaven when I got the overrunning PTO drive coupling!
Thanks for the pictures, great days indeed!
1 Dollar
11-26-2007 19:37:30
 Re: PIC: JD 30 combine 4020 in 2nd crop Saybeans in reply to buck eye al, 11-26-2007 14:07:47
Will probably be using the 1937 A next time (probably wheat). Just got a magneto-drive hydraulic pump to make it useable with this combine. It sure will be an experience.
Buck eye al
11-27-2007 15:20:43
 Re: PIC: JD 30 combine 4020 in 2nd crop Saybeans in reply to 1 Dollar, 11-26-2007 19:37:30
The higher cylinder speeds needed for the wheat will REALLY make you appreciate the live PTO or the overrunning PTO coupling. It can really push you along! You'll get good at shifting out of gear in the split second between tractor driving things and the combine pushing you after the clutch disengages. I actually had a block of wood I shoved into the reverse gate slot of my shifter quadrant to keep me from accidentally bumping reverse when running in first. Usually ran in second with the mid series A so it was not an issue. The B was a late one so never had that problem cause first was so slow.
Wheat was always my favorite crop with these old combines. They actually had pretty good capacity and even in good wheat I could many times run in 3rd with the 46 A which is steppin 'em right off. Clean standing wheat can disappear in a hurry!
They were actually only slow covering the field because of the big sweeping turns, the short cutterbars and how many miles you had to drive to cover the fields. Usually the legs (or scour clean if so equipped) are what will slow you down, especially on a 12A.
Bit of advice if you use a 12A.... leave the header supported by the rod & NOT the cylinder until AFTER you have the hitch unfolded! PUT IT ON THE ROD BEFORE you fold it back too! Get this backwards & you may have need to make some new reel slats or spokes! The weight of the header wants to fold 'em up if the header is held up by the cylinder but does not affect the swinging of the hitch if on the support rod!
Have fun!
1 Dollar
11-26-2007 13:08:14
third party image
This is more of what it was lookin' like toward the end.
Kemper
11-26-2007 12:58:57
I've seen alot more pods with a brand new combine,i wouldn't worry too much about it,maybe bump up the cylinder speed a little,or as you say they may have been getting tough, i have a couple old 30's up in the fencerow that i have never used.
jturbo10
11-26-2007 11:15:03
Can you bump up your cylinder speed and close down the concave a bit to help out with better threshing? JMHO
