Spin On Oil Filter Conversion Kit JD 1010 Gas
Grant Walker
11-02-2007 18:22:44
Does anyone know of a conversion kit that will change the canister type to a spin on type of oil filter for my JD 1010 gas?
GrantW
11-05-2007 06:06:52
 1010 Auxiliary Hydraulic Tank in reply to Grant Walker, 11-02-2007 18:22:44
Does anyone have an auxiliary hydraulic tank that came mounted by the seat for a JD 1010?
Or, exhaust manifold that exits down instead of up?
Also, still looking for a spin on type mount for the oil filter.
GWalker
11-05-2007 06:04:45
Vermont John
11-04-2007 06:22:12
 Re: Spin On Oil Filter Conversion Kit JD 1010 Gas in reply to Grant Walker, 11-02-2007 18:22:44
I'm glad that someone has spoken up about how a properly maintained 1010 is a good little tractor. I like spin-ons, but my 1010 canister uses the same element as my M, so I will still with the old-school approach.
Good luck with the 1010.
Grant Walker
11-04-2007 10:16:19
 Re: Spin On Oil Filter Conversion Kit JD 1010 Gas in reply to Vermont John, 11-04-2007 06:22:12
Thanks. I have a JD 224T baler and the 39hp PTO works great. It has a front end loader that works fine for the home /utility type stuff. I have a post hole auger, a rear blade, pto hay rake and a tow behind hay stacker and a pto sickle. All of these work well. I have an alternator on it, a Genesis solid state distributor (they converted it) and a magnetic oil filter heater so that it starts every time in order to clear the snow. I will never sell this tractor. I've heard a couple of folks a JD dealerships say that the 1010 wasn't a good tractor because it wasn't heavy duty enough. I don't imagine it was ever designed to handle a 200 to 400 acre farm. For a 5 to 40 acre farm, it is great.
Loren NC
11-03-2007 10:27:40
Kit? My 1010 has a spin-on filter with no kit involved.
Grant Walker
11-04-2007 06:12:40
 Re: Spin On Oil Filter Conversion Kit JD 1010 Gas in reply to Loren NC, 11-03-2007 10:27:40
Thank you Bob. If anyone has one of these style filter mounts please let me know.
Also, there is an auxiliary hydraulic tank that mounts just beside the seat for a JD 1010. It is a discontinued item so if anyone has one of these.
Lastly, there is an exhaust manifold that exits down instead of up on the 1010 Orchard model. It is discontinued and I would like to find one.
This has been a great tractor. One thing to mention. I bought the tractor 15 years ago in boxes. The head looked like it hadn't any oil. I rebuilt it and put a new oil pump in. When I put it back together the valves sounded like they needed further adjustment. About 20 hours later the head burned up again. Upon tearing the motor apart, expecting to find a clogged oil passage, I found that JD did not drill out the casting where oil from the rear of the last cam bearing goes then back into the block and up to the head. I drilled this and it has lots of oil now. The speedometer said 800 hours so, I suspect this had been giving the previous owner(s) trouble ever since 1962. Now it not only runs like a deere but after 45 years, it sounds like one too!
Bob
11-03-2007 10:48:19
They changed to a spin-on filter at a serial number 042001.
"TRACTOR SERIAL NO. 010001-042000"
Third Party Image
"TRACTOR SERIAL NO. 042001-"
Third Party Image
The Deere kit to change over to a spin-on filter is part # AT17925, which has been discontinued. The filter base, # T19041, has been discontinued, as well.
David Purkey
02-18-2008 08:18:38
 Re: Spin On Oil Filter Conversion Kit JD 1010 or 2010 Gas in reply to Bob, 11-03-2007 10:48:19
I bought the oil filter base at a used tractor parts dealer in PA. The part was #T19041 and it did bolt on and works great. I had to make a gasket due to the gasket not being available, but I plan to get a factory gasket. The oil filter can be bought from Purolator or the NAPA part is #1243. It is great to not have to mess with the cartridges! The part cost me $35.00 and to me it was money well spent as I change the oil and filter quite often. I wish you the best.
David Purkey
01-28-2008 07:18:42
 Re: Spin On Oil Filter Conversion Kit JD 1010 Gas in reply to Bob, 11-03-2007 10:48:19
Hi,
I have a 2010 gas that I pretty much rebuilt. I recently was wondering if the newer oil filter base T19041 will work on the early series tractors? I bought a base from a used tractor parts dealer and I have not tried it yet mainly because of not having a new gasket. Do you know if I can put the newer filter base on? The bolt pattern seems to be close, but I sure would like to have the spin on type filter.
Thanks!
