2510 jd idiot light on
rkoronka
10-30-2007 05:41:20
My 2510 jd alt. was checked at a shop and it is fine. the top wire goes to the key switch , the bottom wire and the wire on the bolt behind the alt. are tighted together. Is this right? Idiot light will not go off alt belt is tight. Thanks
wannabe
11-05-2007 20:05:44
 Re: 2510 jd idiot light on in reply to rkoronka, 10-30-2007 05:41:20
I have a 2510 and it does the same thing. It has done this for months and I haven"t had a problem, so I just keep on working.
jdemaris
10-30-2007 06:58:33
I don't know if you have the original Motorola or a later Delco of some sort. Either way - the "idiot light" only comes on when there is current flow. When the key is on, but alternator not turning - there is power on side of the bulb, and ground on the other (alt side). But, once the alternator starts charging - the current becomes equal on both sides of the bulb - and subsequently it goes out because no current is flowing. So - if your light is on - you've got a problem on one end or the other. Check it with a voltmeter. Most likely, you'll find the problem on the alternator side - regardless of what the alternator/regulator experts told you.
