'68 1020 lower link hyd. leak
Rob LaFave
09-20-2007 14:13:44
My dad has a pretty good leak from the shaft that runs through rear case and acts as lower arm pivot, I can't seam to find a break down drawing on where and what the seal looks like to fix. Seems like simple fix, but.....
Any help?
Thanks
Gwiz
09-21-2007 18:06:52
 Re: '68 1020 lower link hyd. leak in reply to Rob LaFave, 09-20-2007 14:13:44
That pin fell out of mine once, thought I was going to lose every drop of fluid from the transmission.
James
farmall100
09-21-2007 08:17:31
my 2020 has the same type leak, but not too bad. I've been putting off fixing it. Thanks for the info.
Darwincam
09-21-2007 04:36:48
This may help...reply back if not...
Rob L.
09-22-2007 12:33:29
 Re: '68 1020 lower link hyd. leak in reply to Darwincam, 09-21-2007 04:36:48
I figured it out and was able to print it out, many thanks to you. Seems to be a simple o-ring as a assumed?
Rob L.
09-22-2007 12:45:38
 Re: '68 1020 lower link hyd. leak in reply to Rob L., 09-22-2007 12:33:29
Is that o-ring easy to change by removing shaft or is this a major repair involving breaking down case? I'm guessing the easier fix?
Thanks
Rob L.
09-22-2007 06:15:48
Was unable to open pdf file for some reason? Any link I can look other than that?
Darwincam
09-24-2007 04:34:46
 Re: '68 1020 lower link hyd. leak in reply to Rob L., 09-22-2007 06:15:48
Sorry about that, not sure what the reason was. Glad you were able to get it...that's always a good feeling.
Rob L.
09-24-2007 10:09:35
 Re: '68 1020 lower link hyd. leak in reply to Darwincam, 09-24-2007 04:34:46
It was on my end! I had to reload Acrobat Reader as it was set up for Windows XP and not new computer with Vista. Nonetheless, I had seen that parts diagram before, but didn't think it was the same shaft? Thanks for the clarification!
As I said it seemed to be a simple fix, I hope!
