Your shop probably cooks the parts in a hot alkali bath, using Sodium Hydroxide (lye) as the basic salt, also called "hot tanking". That does a good job on enamels and grease, but it can take much longer to remove modern acrylic paints, epoxy coatings, calcium and rust deposits, if at all. Abrasive blasting does a geat job to remove everything on the surface, but it takes some of the base metal along with it, and it can warp thin metal parts and erode finished machined surfaces. You might want to try the electrical equivalent of hot tanking by using an electrolysis bath. Using a low voltage power supply, such as a 10 A battery charger, to ionize a conductive fluid (typically washing soda and water) so that it works like lye, in fact much better than an alkali cooker because it lift the deposits as well. The most impressive added beneift of the e-tank is that any red rust will either float away or be converted into black oxide, which is inert to further oxidation. The surface can be rinsed with clear water (hot makes the part warm so ti dries faster), spritzed with some phosphoric acid to flash phosphate protect the clean iron/steel from re-rusting, let to dry, then scuffed smooth with some red Scotch-brite, and the part is ready for paint. It's cheap, safe, and effective. Pretty muich like aspirin. I have a document that I can e-mail you if you would like to study the "how-to" of the process. Shoot me an e-mail at frank@fboerger.com if you would like me to forward you a copy. On the powder coating, I've seen it tried, but I have never seen it stand up on the high temperature side. You really need to use a ceramic product like Jet-Coat if you really want it to stick, stay, and not dis-color. Frank
