Which is the correct part # for this 420 tach
riggsjr
02-10-2007 16:41:33
What is the difference in these 2 tachs.There are both suppose to be for a 420W.One is marked ..AT1776T and the other is marked...AT17443.I think the second one is a repro if they make repros?Can someone tell me the difference and which is an orignal or are they both?
Thanks....
Henry M
02-11-2007 18:52:28
 Re: Which is the correct part # for this 420 tach in reply to riggsjr, 02-10-2007 16:41:33
I am not a correct policeman, so I got my new 420 tach at Mother Deere. Works good, looks good, and suits me.
riggsjr
02-11-2007 08:27:52
Do you know where I can get one?
Ten-Twenty
02-11-2007 08:33:45
 Re: Which is the correct part # for this 420 tach in reply to riggsjr, 02-11-2007 08:27:52
riggsjr,
Put a "wanted" ad in the YT Classifieds. A "working" used one will probably set you back $200.00 or more.
riggsjr
02-11-2007 07:52:11
Are th 1010 tachs the same on the 420's.Why do some have hour meters and some do not.Was that an option or diffeent tachs for different models?
Ten-Twenty
02-11-2007 08:20:09
 Re: Which is the correct part # for this 420 tach in reply to riggsjr, 02-11-2007 07:52:11
third party image
The tachometer was an option on the Model 420.
Here is a photo of an "original" tachometer for a Model 420 with the 5-speed transmission (a 4-speed Model 420 would use a 4-speed tach). Notice the number on the face (under the John Deere) is similar to the AT 1776 T number you referred to earlier, but appears to have an additional numeral.
riggsjr
02-11-2007 07:45:10
I am looking for a 5 speed tach,but an original. I think the part # AT17443 is for an OEM.Do you know what the corrct part # would be for a 1958 420W or where I can get one?
Ray
02-11-2007 18:56:00
 Re: Which is the correct part # for this 420 tach in reply to riggsjr, 02-11-2007 07:45:10
There's usually one on ebay.A couple years ago i put an add on this site for a used one.A guy in canada sold me 5 working originals for 90 bucks.
I used the last one a couple months ago.
Ten-Twenty
02-11-2007 06:20:09
riggsjr,
AT1776T does not show up as a valid part on JDPARTS. Are you sure you did not leave out a numeral in that number? AT17443 shows up as a tachometer for the JD 1010 (it subs for AT13366). The Model 420 parts book does not show any of these numbers, but it is possible the AT17443 tachometer is a replacement part for the 420. Next question, are you looking for a tach for a 4-speed or 5-speed?
Wayne in Tn.
02-11-2007 09:14:28
 Re: Which is the correct part # for this 420 tach in reply to Ten-Twenty, 02-11-2007 06:20:09
The tach for a 420-W ...5 Speed:
Miles per hour...#AM3492T
Kilometers per hour ... # AM3716T
These are the original part numbers, but I think if you get the tach from Deere, they will sub these numbers and the tach you will get will have colors in the face instead of black and white.
