$1: I cannot get your link to governor pictures to open. I can back into all of the paint job photos, but those do not show any detail. See if you can get detailed photos posted up. In the meantime, go back and tell us EXACTLY what you removed from the point of the tractor running right and how you re-installed it up to now. By this I mean, did the tractor run fine with the big nut ccarburetor, then you removed the rod from the throttle pedestal to the governor spring, and then the rod from the governor ARM to the carburetor butterfly. You didn't try to install a choke rod or another rod that was laying around the shop did you? On the governor, please confirm that when you do the half hole test that: - The throttle is in wide open position - The carburetor butterfly is in the WIDE OPEN position, not against the idle spring. You have to hold it open with your left hand - The governor arm to butterfly rod is 1/2 to 1 hole SHORT. - When running, throttle in aft position, move the carburetor butterfly from idle to mid range while holding to the governor rod with your right hand. As the engine picks up speed, the rod should push forward in your hand (if I'm remembering my A's right...) as if it would close the carburetor butterfly if it was connected. Confirm all of this step by step. I ask you to confirm that because there have been cases where someone has the throttle back or the carb butterfly closed and then the measurement for the rod is wrong. Confirm that the throttle lever rod goes to the leaf spring on the governor arm, not the arm, and that the governor to carburetor rod is going from the governor arm to the carb, not the governor leaf spring to the carb (though I'm not sure you even get it to fit like that)..... Frank
