Size of antifreeze drain holes on heads
1 Dollar
12-01-2006 20:31:02
I ordered an engine block heater that fits in the drain hole of supposeably all 2-cyl. heads because they all used a 3/4 plug. My 1937 A has a plug that is much closer to 1/2 and I was just wondering what size other models have. This A does have a powerblock and I don't have a clue what head it has on it, I think it is JD but have no way of immediately telling. The heater is from Sharp's so if it doesn't fit they are easy enough to deal with on a return.
Thanks
CENTAUR
12-01-2006 22:34:28
 Re: Size of antifreeze drain holes on heads in reply to 1 Dollar, 12-01-2006 20:31:02
If its NPT thread simply use a ordinary National Pipe Thead reducer.I am at a disadvantage I can not see from here the physical properties of what you got.CENTAUR
