1530 hydraulic problems
ricky sparkman
10-05-2006 15:09:07
useing my 1530 the steering and three point hitch stops working.Shut the engine off for a couple of minutes.Crank the tractor and they will work for a while and do the same thing again any ideas.Thanks for any help.
mowr
10-07-2006 09:16:45
 Re: 1530 hydraulic problems in reply to ricky sparkman, 10-05-2006 15:09:07
I think something is blocking the flow of hydraulic fluid. I've seen this happen when a quick-coupler on one of the remotes went bad, allowing the ball inside to block the fluid. The snap ring that was supposed to keep the ball in place had popped out and also an o-ring in the valve in the lift housing under the driver's seat had failed.
