You know guys, I've got a pretty knowledgeable paint guy who has worked in that industry for many, many years, and he told me that the Omni hardener was not compatible with synthol paints, and directed me to a brand that clearly said "for Synthetic Enamels". Another fellow who used to stop by here maybe three years ago was a PPG rep and very specifically said that the common synthol hardener was not the same as the Omni stuff. Now, maybe I'm not referencing that same Omni product as before, and if not, I'd like to know because it would save me some driving the next time I need hardener/catalyst, so I'm just asking for as much detail and no hearsay, because we've all been the victim of that over the years. To add a bit of history here, any of you who remember Clooney, one of his quotes, was "lately I have been using Autobody Master Synthetic #8132 hardener but have used NAPA #8010 in the past I can't see any difference. You want to make sure the hardener can says "synthetic" or all you are buying is real expensive reducer. Using the wrong hardener will probably give you a little better gloss because it isn't doing anything but acting as a reducer & you can get the same thing by just adding extra reducer in the same amount. I have found that the gloss factor is actually just slightly better without hardener but not enough to not use hardener," (reference YT thread url >Link So, among my questions are: Do you get a hard finish, along with reduced drying times using the Omni product with JD Synthetic Paint? The correct hardener SHOULD speed up the cure times along with making the finish more resistant to scratching and bubbling up from fuel. And...have you ever had the opportunity to apply a non-synthetic finish such as acrylic enamel and compared the two finishes? When I apply AE with the correct reducer and hardeners, the finish flashes pretty fast between coats (like twenty minutes for re-coat), and after multiple coats, those parts are dry enough to handle in less than two hours and too hard to recoat without scuffing with light grit paper or Scotch-Brite. You really could be just using an incompatible hardener that, while not really ruining the paint chemistry, is of no improvement either. So, as Clooney said, you really could be using hardener as an expensive reducer, and that's what I want to avoid. Frank
