JD B fly wheel
ringy
02-24-2006 11:24:19
This refers to a previous post about a high school students stuck fly wheel. We determined that he has the older style with the bolts on the inside. Anyone know offhand what size wrench we need to modify to get those bolts out?
CalJim
02-24-2006 21:27:31
 Re: JD B fly wheel in reply to ringy, 02-24-2006 11:24:19
Hello, You do not need the special wrench to remove
those flywheel bolts. Use 1/2 drive ratchet,
short extension and 1 1/16 socket. It will not
rotate far enough to click so you have to remove
it and turn socket slightly, reapply,turn,etc.
Re-install the same way. Thanks
Ravgardner
02-24-2006 17:09:17
The JD flywheel wrench is the only way to get a grip on those nuts. Unless you can make wrench that reaches behind the wheel and then be able to apply som torque. Try to find someone local to borrow one. Or buy one on ebay for around $50.
Larry806
02-24-2006 19:35:55
 Re: JD B fly wheel in reply to Ravgardner, 02-24-2006 17:09:17
Where are you located?
Ravgardner
02-27-2006 11:23:17
 Re: JD B fly wheel in reply to Larry806, 02-24-2006 19:35:55
Ithaca, New York
Maark
02-24-2006 15:36:02
The parts book calls for a 5/8" nut. It could be anywhere from a 15/16" to 1 1/16". In some applications Deere used a heavy duty nut which could make it either 1" or 1 1/16"
