2510 D
Rob NC
01-26-2006 10:33:45
can someone tell the shipping weight of a 2510D with the rom, and also the reliability of these tractors. i have been looking one equipped like this with the 2 remote valves and a jd loader. i have run across a few but looks like a good road trip ahead.
Rob NC
01-26-2006 14:08:26
 Re: 2510 D in reply to Glen in TX, 01-26-2006 13:44:54
thanks glen, i forgot to ask this earlier but what model loaders will work on this tractor. there are several #148 loaders coming up on auctions within the next several weeks,thought i would go and see what they bring.
Glen in TX
01-26-2006 15:53:26
 Re: 2510 D in reply to Rob NC, 01-26-2006 14:08:26
The 148 loader is a popular one that will fit it with the right brackets. You may want to check with your local JD dealer or others local to see what brackets are available for which loaders to fit it as it will be a bit narrower than like a 4020. That will save having to fabricate brackets. I forget which other numbers fit but you might find some listed in archives here.
ljl
01-26-2006 18:11:54
 Re: 2510 D in reply to Glen in TX, 01-26-2006 15:53:26
sorry glen but a 2510 252o 3010 3020 4010 4020 and etc tractor frame with are all the same differance come in lenght 4cly against 6 cly but the mounts can be shortend witht the blue tip brackets are the sae for all the above have a nice day larry
Glen in TX
01-26-2006 18:51:59
 Re: 2510 D in reply to ljl, 01-26-2006 18:11:54
I see now he said 148. If they are all the same width and length then why is someone here always having trouble finding brackets to fit? I noticed you stopped at 4020. So is there is a large frame bracket for the 4320 and up for the 148 or it won't fit those? The 48 loader manual shows will also fit 2510,3010,4010,4020 with rail brackets and 1020 & 2020 with frame brackets.
matthies
01-26-2006 20:12:47
 Re: 2510 D in reply to Glen in TX, 01-26-2006 18:51:59
I've changed brackets between a 3010 to 4430 and 3020 to 4320 with no problems on 148 loaders. chris
Glen in TX
01-26-2006 21:14:34
 Re: 2510 D in reply to matthies, 01-26-2006 20:12:47
Ok, It must be a later model JD loader I'm thinking about that someone here had problems fitting on a 2510 or 2520 ?
Rob NC
01-26-2006 11:28:01
 Re: 2510 D in reply to Rob NC, 01-26-2006 10:33:45
i found that info in the achives
