powerblock
jdjerry
11-12-2005 11:15:21
what is the difference between the 6-2 and the 6-3 powerblocks?
730-LP
11-12-2005 18:00:27
 Re: powerblock in reply to jdjerry, 11-12-2005 11:15:21
They have different bolt patterns where they bolt to the main case.The no.2 fits 1940 thru 1949 the no.3 fits 1950 and above and the modle 60.
Drew
11-12-2005 17:55:57
third party image
6-2 fits sn 584000-648000 and the 6-3 fits sn 648000 and up and the 60.
In the picture, left to right is 6-1, 6-2 and 6-3.
Wes W.
11-13-2005 10:41:43
 Re: powerblock in reply to Drew, 11-12-2005 17:55:57
Does anyone know where I can find a powerblock for my '48 B? I'm fixing it up for my grandson to pull with.
Thanks,
Wes W.
1 Dollar
11-12-2005 19:20:01
Does the 6-1 fit the unstyled A?
Thanks
Drew
11-13-2005 16:47:06
 Re: powerblock in reply to 1 Dollar, 11-12-2005 19:20:01
The 6-1 will fit sn 410000 to 584000 (unstyled and early styled). The block itself will bolt right in an unstyled chassis. You must use a styled head/pushrods/rocker gear. The pistons also use the styled 1.750 wrist pins.
It you are concerned about starting it, its not hard to put petcocks in it.
DickD
11-13-2005 03:40:32
Dollar; I see you asked about a power block for an unstyled tractor. Just a word of advice. We bought an old A which my son got running. He was 15 and couldn.t drive so this was his transportation. The more he drove it the better the rings seated. It got so hard to turn over, that it was nearly impossible to start by hand.
Just my 2 cents
1 Dollar
11-13-2005 18:32:12
 Re: powerblock in reply to DickD , 11-13-2005 03:40:32
I'm 14 so I know how he feels. The only way I can start mine is just let the compression slowly leak past the rings and then turn it over. Luckly it does this or else it would be impossible to start. Kinda funny the be happy about losing compression. Anyway, how big is this engine. I was just wondering.
Thanks
JD Jerry
11-14-2005 05:20:54
 Re: powerblock in reply to 1 Dollar, 11-13-2005 18:32:12
Dollar, the A has 321 cu in. from the factory and the older ones around 310. Rummys has the data on their home page. Jerry
