Live hydraulics on B
rjohn wi
10-17-2005 19:34:11
I have a 1950 B and would like to have live hydraulics on it. I have a pump that goes by the mag but wonder what I have to do to connect it to the existing pump. Where the hoses go, if the gears have to be removed on the existing pump, or something about a block that has to be put in the old pump to block a port. Thanks a lot for your help. Roger
Mike M
10-20-2005 09:37:57
 Re: Live hydraulics on B in reply to rjohn wi, 10-17-2005 19:34:11
Sounds like you kinda have it figured out. You need a spacer plate to go between the valve box and the housing,2 gaskets 1 on each side of spacer. The pto pump will need the idler gear pulled out. If you use the factory set up for the suction line that goes in the bottom where the oil drain is you will need to tap the hole out bigger as the special elbow fitting has a stand pipe on it and is of larger size.I have seen some that just used what size was there with an elbow.
