JD B Valve Adjustments
Rob Broehl
10-11-2005 06:21:04
Does anyone know what the intake and exhaust valves should be adjusted to when COLD? The manual states 0.020" hot, but nothing about cold.
Mike M
10-11-2005 06:47:33
 Re: JD B Valve Adjustments in reply to Rob Broehl, 10-11-2005 06:21:04
cold is .022 "
F-I-T
10-11-2005 07:31:01
 Re: JD B Valve Adjustments in reply to Mike M, 10-11-2005 06:47:33
Mike:
I seem to remember that you can also turn it in to touch, then back off 2 flats. I don't have those notes with me so maybe you or someone else could confirm. I just did that math based on a 7/16" diameter, which I got from the parts book, and I think it is a coarse thread, which would make it a -16 pitch, so each turn of the nut would yield .0625", so two flats would set the clearance at .02083, which really helps when you have old rockers that have a depression worn that won't allow a flat surface to use your feeler gauge properly.
If those numbers are wrong, please to unregard!
Frank
DRL
10-11-2005 15:03:59
 Re: JD B Valve Adjustments in reply to F-I-T, 10-11-2005 07:31:01
Yep, tighten down while turning the push rod until you feel resistance, then back off two flats, or 1/3 turn. This is the best way to do it if the tappets are worn. This is straight from SM-2004, page 60-10-10.
