37A powerblock
1 Dollar
10-05-2005 18:26:08
I was wondering what you guys could tell me about the powerblock that is in my 1937 A. It is exactly 12 inches long, has no petcocks (thats fun to start), and has a raised block with maybe and 8 on it and next to that it is flat again and has what I belive to be a 7. It also has what I assume to be a SN tag with 295 on it. They all are arranged like this.
Front
8 7
295
Rear
This is on a 1937 A.
Thanks
Leroy
10-09-2005 07:23:32
 Re: 37A powerblock in reply to 1 Dollar, 10-05-2005 18:26:08
I believe it may be a Heisler block, a post since yours on over high compression on a B mentioned an hi compression Heisler block as well as a heigh compression Heisler head
Duane Larson
10-06-2005 10:48:24
1 Dollar,
Power Blocks came with the letters Power Block and the size in inches, followed by a number indicating which series they fit, for example 6" 1. The letters are cast in the top, between the water outlet and the back of the block. While the letters could have been ground off, I'm not familiar with the cast numbers you have on your block. It must be some other aftermarket block. You might inquire on the pulling board - someone there may identify it.
