oil seal on model 70
RoMic
09-19-2005 04:40:12
What is the best way to remove the oil seal/spacer that is located behind the flywheel on my model 70? It looks like it has a thin lip around the outer edge that a puller might mess up. Thanks in advance guys.
BushogPapa
09-19-2005 06:27:08
 Re: oil seal on model 70 in reply to RoMic, 09-19-2005 04:40:12
I assume you have a "Gas" "70"...??
The Slinger has an "O-Ring" packing in it that seals it against the crankshaft.. With the outer cover removed, it should slip out without too much pressure. A New packing "O-Ring" can make it pretty hard to slip back on.. If you wipe the slinger off and use a rubber strap-wrench, I am sure you can twist and pull on it at the same time and get it to move..
Ron..
