MT piston rings
Rob in MI
09-08-2005 18:48:04
I have a MT, that I bought with a cracked head and a small crack in the block. I have the head ready to install. I figured I would fill the radiator with water, with the head off and see what happens. After a couple of minutes a little water started seeping from the oil pan plug. I removed the pan and each cylinder had water in it,(I overfilled the dang thing) but water seemed to be dripping from the rear cylinder so I removed the piston, but still can"t see any cracks. Could I just have some really worn rings or what??
Bus Driver
09-09-2005 05:09:28
 Re: MT piston rings in reply to Rob in MI, 09-08-2005 18:48:04
Piston rings have nothing at all to do with water from the cooling system getting into the crankcase. Take a small engine class at a community college.
