JD B Oil Leak Question
Rob Broehl
08-08-2005 13:20:07
Hi everyone,
I just purchased my first real tractor (a hand start 1944 JD B) and have an oil leak that appears to be coming from the clutch shaft/pulley. I cannot see it , but there is oil running down from that point and the pulley has oil along the edge.
Anyone know what might be wrong? It is an older restoration and this is the only problem I have found so far.
Thanks.
Rob
F-I-T
08-08-2005 18:14:52
 Re: JD B Oil Leak Question in reply to Rob Broehl, 08-08-2005 13:20:07
Rob:
Well, there is no real oil seal. The sealing depends on a tight bushing to crank clearance. Sometimes these get overlooked and then they will dribble oil down the crank and into the pulley. There is also a slinger built into the operating sleeve that is pretty effective if the engine is kept at a higher speed when idling. Could be that the right hand main bearing is leaking as well.....but probably , the bushing is far too worn.
Frank
