2010 rim stuck to hub
Rob Klepinger
06-17-2005 20:13:29
I have a 2010 that got a rear flat, tried to remove the rear rim off the hub, the nuts came off the bolts easy enough but the bolts seem to be rusted to the cast hub. I don't want to break anything, the blocks the hold the rim to the hub look like they are cast iron too. I put a nut on one of the bolts and hit it with a sledge hammer but just dented up the nut. Should I try hitting the cast block that holds the rim to the hub, heat up the hub? Any suggestions are welcome.
Thanks! Rob
Tom in Mo.
06-18-2005 05:09:28
 Re: 2010 rim stuck to hub in reply to Rob Klepinger, 06-17-2005 20:13:29
The cast wedges have a tremendous amount of force on them while tightened down and in place. Squirt a little wd-40 or equal on all the wedges and bolts and tap around on the wedges as well as the bolts. Don't pound 'em just beat 'em; they will come loose all at once so BE CAREFUL or you'll be wearing a hospital gown.
