A JD for 5000USD with 70+ hp is extremely rare find. Personally, a good AC 185 might be had for 5000USD (and even that is stretching it)...but it doesn't have TRUE live power PTO, which in my opinion is a MUST for running a snow blower. You might find a good IH for around 5000. It has been some years, but my Dad's 856 (with M&W turbo) went for 5200USD on auction. That was a steal in my opinion given the shape it was in (course it was a real cold blooded pain in the...). An oliver might be another choice. Just make sure the over/under works. A 1655, 1755, or 1855 would be nice strong tractors and should have plenty of hp and have live PTO if I recall correctly. Seen some larger Fords go for reasonable prices for the hp. Something like a Ford 6600, 7000, or 8000. Secondly, a 6 foot snow blower is too narrow, unless you are going to move your tires on your tractor in to 6 feet (which I wouldn't recommend). The reason for needing a 7' or 8' snow blower, is so that your rear tires are not plowing/spinning in the snow that cannot be reached by the blower (or blade or loader bucket for that matter). 5' to 6' drifts are not necessarily common. Really depends upon location of trees, buildings, and of course amount of snow. I've lived in many parts of MN for all my young life (35+ years) and only about 3-4 times recall drifts so big. As to the cold temperatures, unless you have animals that require a tractor to feed them every day, you generally won't need to be starting your tractor at anything 10 degrees below zero (doesn't snow heavy when it is that cold). It still is a good idea to have a block heater or a tank heater installed on the tractor just in case you need to start it. Depending upon age (and whether gas or diesel), they may not start too well below 30 degrees F. And as to mowing grass, a 425 is pretty good. I have a JD 317 which I used for about 3 years (bought...extremely used) to mow about 3 acres of rather rough terrain...including pasture. I blew a hole in the engine, and ended up getting a deal I could not pass up on a JD 445 (2001). I can mow all those 3 acres and more in half the time as my old 317. Essentially the biggest difference between your 425 and my 445 would be the tires. The larger tires allows the 445 to go places your 425 could only dream of going. So depending upon terrain you may or may not be able to do every thing with your 425.
