R help
rman
02-20-2004 19:09:04
we repaired fuel leak on our r at ful tank now cant get start we bleed fuel lines and filters full what are we doing wrong thanks in advance
Clooney
02-21-2004 05:54:13
 Re: R help in reply to rman, 02-20-2004 19:09:04
Rman, if it ran before the fuel tank repair & won't start afterwards it sounds like you have an air problem..
~If you cranked that engine before completely bleeding the filters & lines you probably now have an air lock in the injector lines between the pumps & injectors.. You will probably need to pull the valve cover & bleed the injector lines right at the fuel injectors.. Just crack the injector fittings at the injectors & with the fuel lever advanced crank it with no compression.. When the fuel flows clean with no air tighten the fittings & try starting it..
JDClooney@aol.com
