AR throttle linkage??
Rob in MI
04-05-2005 07:20:06
Does anybody have the throttle linkage for a 45 unstyled AR from the carb to governor? I was trying to adjust mine yesterday and the end that screws on for adjusting broke on me, now it is too short. I am also looking for a belt pulley brake for an unstyled D cast# D 62 R. Any help is greatly appreciated!!
bent
04-06-2005 07:40:03
 Re: AR throttle linkage?? in reply to Rob in MI, 04-05-2005 07:20:06
Rob, there is lots and lots and lots of U/S AR's in wrecking yards. As a matter of fact I know of 3 or 4 wrecks within 10 miles of me. That part should not be too hard to locate at a nearby wrecker. Let me know if you get stuck for one and I will see if I can help out.
bent
Rob in MI
04-07-2005 18:10:39
 Re: AR throttle linkage?? in reply to bent, 04-06-2005 07:40:03
Bent, Yeah I could use one if you could get me one. IF you email me we can talk things out.
Maark
04-05-2005 11:13:59
For that throttle linkage,measure it with the broken end laying like it should be installed, then cut off the linkage a little ways back and weld a 1/4" bolt the correct measurement back on. Make sure you taper the ends that are to be welded so that it can be ground down to look respectable again.
Rob in MI
04-05-2005 17:59:19
 Re: AR throttle linkage?? in reply to Maark, 04-05-2005 11:13:59
I thought about doing that, but I was hoping to find someone with an original to replace it, or better yet a NOS. Thanks for the suggestion!!
