casting number
rmiller
03-22-2005 20:08:01
What is the casting or part number on an early styled b clutch housing cover?It is b 2780r on the late styled ones.Mine is a 43 and i cannot make it out.It is something like b1054r.i can only make out the 1 and 4 for sure.This is the 4 bolt assembly that goes onto the reduction gear housing,it also has the pulley brake arm on it.Mine has a lot of wear and I need a better one.I bought a good b2780r off of a 50 but was told later that it will not work.
Jason Z in MO
03-23-2005 08:15:27
 Re: casting number in reply to rmiller, 03-22-2005 20:08:01
Per the parts book:
Part # AB3931R was used from SN 96000 to the end of the B production. The casting numbers for this part is B1854R and B2780R
This is more appropriately called the clutch fork bearing housing.
I would say your old worn part is B1854R so the one you bought B2780R should work!
Jason
rmiller
03-23-2005 15:16:47
 Re: casting number in reply to Jason Z in MO, 03-23-2005 08:15:27
Thank you Jason Z.for your very helpful information.I sure appeciate it.I am new to the hobby and I assumed the person I asked knew what they were talking about. I just went and measured both of them and the bolt centers and they sure look like they will interchange to me.This saves me time and money looking for something I already have.Soon as the weather warms a bit I will find out.Thanks again.
Jason Z in MO
03-24-2005 06:11:35
 Re: casting number in reply to rmiller, 03-23-2005 15:16:47
Not a problem! Glad I could help. I am working on a 1940 B SN 81291, if there is anything else I can help with don't hesitate to ask.
Jason
