Rob, I have no specs or data on that coil you have, however, if its a 6 volt coil (like when Deere used a 6 volt coil on a 12 volt system and ran the external Ballast Resistor) it would be in the 1.25 to 1.75 ohms range in its primary measured between its lil + and - terminals, and if a 12 volt internally ballasted coil, somewhere in the 2 to 3 ohm range. Regardless of points or elec ignition, you gotta have that voltage on the coils high input (NOT to distributor/switch) side when the Ignitions switched on (that means the switch is good and the ballast isnt open) ,,,,, ,,,,,continuity in the coils primary (between lil + and -),,,,, ,,,, and then: When the points or elec switch is closed (which it usually is, only open when switch momentarily opens and coil fires at pistons TDC's), theres near ZERO VOLTS on the coils low to distributor/switch side. Then ONLY when the points or elec switch open, theres momentarily battery voltage on even the coils low to dist/switch side as no current (besides meter) is being drawn. NOWWWWW WWW when you say you have near battery voltage OUT OF THE COIL, is the elec switch all wired up correct and the ignition on????? ??? CUZZZZZ ZZ if all is working and unless one of the pistons is at TDC and ready to fire (which they cant hardly come to rest there) the elec switch (or points) are normally closed and supposed to conduct coil current to near dead ground IN WHICH CASE THERE SHOULD BE NEAR ZERO VOLTS ON THE COILS LOW SIDE!!!!! !!!!! !! If all is wired right n working and on THERE USUALLY SHOULD BE NO VOLTAGE ON THE COILS LOW SIDE or else the switch either isnt conducting current ORRRRR RRR its not getting it to ground. 1) Are you sure that BOTH wires to the switch (usually a black n white, one to voltage other to coils low side) are in place???? 2) The switch has to get a ground return path, even if its good it grounds inside the distributor base etc., how is it attached inside??? If youre reading voltage on the coils low output (to swich/distributor) side, that tells me the coils primary is good and continuous and the switch n ballast n input side wiring are all good also. Sooooo ooooo that leads me to believe the problem is either a) Switch is bad or not wired correct, or b) Switch or wirign are NOT gettign a good ground, cuz if working, theres normally (except at TDC and ready to fire coil) ZERO, NOT BATTERY volts on the coils low side. c) Is the hot feed wire to the switch wired ahead of the ballast and NOT on the low to coil side????? ???? I think they get full battery NOT reduced ballasted voltage. d) Is the switch body or any extra ground wires well attached to distributor and is distributor well grounded???? CUZ IF THE COIL LOW SIDE NEVER SEES A DEAD GROUND (when switch is closed) THE COIL NEVER CONDUCTS CURRENT AND SHE WILL NEVER FIRE. She acts like the switch isnt closed n conducting coil current either from mis wired or not connected to a good ground. For the coil to fire, she has to have input voltage,,,,, ,,,conduct current to ground (via closed points or switch, dropping output voltage to ZERO NOT 12 AS YOU SAY),,,,, ,,and then momentarily open and interrupt that current flow (switch opens at TDC) Let us know, Good Luck n God Bless John T
