Rob, if Denny specified and had you install that particular coil and the associated series Ballast resistor on a 12 volt negative ground system (and thats what you have), to answer your question, NO I dont think you blew it by using the resistor !!!!! !!! Its reverse poilarity they dont like!!!!! !! All it does is reduce voltage and limit current both through the electronic switch and that coil and if Denny specified it, hopefully, it was proper and required to match the coil and elec. switch. HOWEVER, here's somethign you may want to check with Denny and take a look at: That elec switch probably has 2 wires out of it with one wired to 12 volts and another to the coils - terminal. When using a ballast, that hot wire may be need wired ahead of the ballast off the Ignition switches IGN output terminal instead of the coils + side !!!!! !! since after the ballast voltage drop that may be nearer to 6 versus 12 volts????? ? Where is it wired currently????? For it to work, when the ignitions turned ON and assuming the switch is working and conducting current, there should be battery voltage out the switches IGN output terminal,,,,, ,,, battery voltage on the ballast high input (from switch NOT to coil) terminal,,,,, ,reduced voltage (maybe 6 or so) on the ballast other low side and coils high input terminal,,,,, ,,,,and near zero volts on the coils other low (to distributor) terminal. Then as the engine is cranked a test lamp or voltmeter on the coils low (to distributor) terminal should be usually off and flash (but depends on switch speed and type and quality of voltmeter) on (switch opens) and off (switch normally closed). For the coil to produce a spark out its high voltage secondary tower, its low voltage primary (between lil + and - terminals) must conduct current (switch closed) but then be interrupted (switch opens) momentarily. Check the switch wiring to see if its supposed to be on the ballast low output (6 volt) or its high 12 volt side (switches IGN output) as I suspect. Let us know, Good luck n God Bless n Merry Christmas John T
