Rob, this may be a lil tough to troubleshoot over the net, but that POP from the distributor/coil area you mentioned sounds a lil scary to me, however, I will give you my best shot. First, you mentioned "resistor" usually with an elec switch you toss any old Ballast Resistors (which fed a stock 6 volt coil) and use a new internally ballasted full 12 volt high performance coil. If it has a Ballast and a 6 volt coil, the Ballast or its wiring could have went bad/open. The Ballast is series between the Ignitions switches IGN terminal and the Coils high input terminal. If its open, the coil or switch gets no voltage and wont work (see below) Heres some basics you need to make her work, regardless if points or an elec switch. Use a simpe test lamp and::: 1) Turn the Ignition ON and you MUST HAVE Voltage present on the Coils high input (from switch NOT to distributor) terminal. It powers the Coil and feeds the elec switch. If theres no voltage on the coils high input terminal, the problem may be a bad switch or an open wire from switches IGN output terminal down to Coil, or an open Ballast (if it has one). No kind of coil Ignition (points or elec switch) is ever gonna work until you power up the coils high input side when the Ignition is ON (Check this first) 2) Once you have voltage on the coils high side input, turn the Ign ON and crank the engine over. Place the test lamp over on the other coil terminal and as cranked it should flash ON and OFF there. If it never flashes ON, the coils primary winding (between lil + and - terminals) may be bad/open,,,,, ,,,,, or the elec switch is bad/dead shorted,,,, or some wires from coil to elec switch or where it feeds thru distributor housing??? (check those wires) are dead shorted. If it never flashes OFF, the elec switch is bad or wires are open between coil and switch, or the switch is baddddd ddd. You can do a preliminary coil resistance check to insure its not open, its low voltage primary (between + and -) should be from around 1.5 to 3 ohms, while its high voltage primary between one of the lil terminals and the high voltage tower output, should be several thousand ohms. If the coil is good,,,,, ,,,coil has power when Ignition is ON,,,,, ,,and theres no open wires or shorts (especially where wires feed into distributor),,,,, ,,,,Im feared the elec. switch may be baddddd ddddd d. As Bob noted, reverse polarity can wreak havoc on them critters. Lemme know, Good Luck John T in Indiana
