JD435 Diesel PTO
Rob Johnson
11-27-2004 12:12:40
There is a good chance I will be finally getting my dream , a 435 diesel.
But I have to convince the "ball and chain". I have to be able to show her this tractor is a strong performer with the PTO , that I can expect little or no trouble with lots of heavy PTO use.
Can anyone advise me on just how trouble free the PTO is ?.
Rob J
buickandeere
11-27-2004 23:11:21
 Re: JD435 Diesel PTO in reply to Rob Johnson, 11-27-2004 12:12:40
AS long as you don't let your foot slide off the clutch pedal and start a heavy pto load with a jolt. She should be fine. 33HP from a two stroke two cylinder is less stress than 27HP from a fourstroke two cylinder.
Mike M
11-27-2004 16:44:01
I have never ran a 435,but any other 2 cyl. engine is hard on pto equipment. Not enough cylinders to smooth out the power impulses.
Henry J
11-27-2004 14:39:50
Rob
Might be a good thing to sell it on. But I don't think it would be a good idea to buy it so you can work that pto like a dog. There have been many references to the cluster gear blowing in that dubuque (being the same as or close cousin to the late 420/430).
I do have a trans case that was 5 speed and live pto that the cluster blew in it. At best it will only crack the side and bottom - ouch.
Sorry to be the oger during the holiday season. Maybe a bunch of folks will follow up with great praise for the dubuque pto taking punishment.
But I do agree, YOU NEED THAT TRACTOR
Bob in GA
11-27-2004 20:32:34
 Re: JD435 Diesel PTO in reply to Henry J, 11-27-2004 14:39:50
I have had a 435 for 3 years and have used the pto for mowing. I would not call it heavy work, but I have never had any problem with it. Since the 435 has the 2 cycle GM diesel, it does not have the impulse problem of a regular JD 2 cylinder, so that is not a problem. I have too agree though that I am not sure that heavy lugging would be good on the gears, but running it without overloading it should be ok. Good Luck
