With all of the respondents on this site, I know some interesting discussion can be had on this topic. When attending plowing days, etc., has anyone compared the performance of various Deere tractors of the ages? How about a newer 50-60 hp Deere (5400 or whatever) against a 730 diesel? How about a 730 against a 3010 or 3020, same field, same day? How about a styled G with some of Mr. Hindrich's pistons against a 70 or 730? I realize this is a little like comparing sports superstars of different ages (O'Neal vs Chamberlain comes to mind) but this is doable. Try to keep the comparison as complete as possible; I have to believe that there are a lot of these types of experiences out there; please share.On the side of the question...I keep hearing that appropriate timing on the Waterloo lettered series like my '49 G is about 25BTC. I am running mine at 19BTC; doesn't idle terribly well but really comes alive under load. I set w/ timing light. I have no close dyno access. On a long hill pull, tractor seems to have a little more power there than at 26BTC. Am I deluding myself? Tractor has electronic ignition and 55KV coil. Question 2-I have the F1074 gas manifold. Am pondering a Heisler or Johnson manifold. The cam is stock and since I've redone most everything ahead of the crank including the clutch, I don't have an overwhelming appetite to dig into a cam change to up flow past my mild porting. Does anyone have experience with the cold manifold in the absence of the optimised cam? Any idea on power increase? Thanks in advance for your help! Regards, Rob ps- my $0.02 worth, Wilt in his heyday over Shaq; not even close.
