JD 5020 Please HELP!!
rjb
09-01-2004 18:48:05
I am looking to buy a 1967 JD 5020 tractor from a dealer I asked him to run a dyno test on it and he came back and said that it produced around 130 hp...I know that it is rated at 133 HP, but I thought that John deere was being Conservative on this rateing!??
I here from time to time on this sight that the JD 6030 is rated 176 HP but produced over 200!! on the Dyno.Is this the same story with the 5020??
Plesae help with this...
Thank you..
TB SCOTT
09-02-2004 09:14:21
 Re: JD 5020 Please HELP!! in reply to rjb, 09-01-2004 18:48:05
you didn't mention if it has had a turbo put on it or not...alot have. My 5020 is the 78Th built unbutchered original never had a turbo added and it dynoed at 129
rjb
09-02-2004 09:55:30
 Re: JD 5020 Please HELP!! in reply to TB SCOTT, 09-02-2004 09:14:21
This is a NON turbo Natualy aspirated engine it was built in 1967
tipton
09-02-2004 08:32:28
I have a 1967 5020 with a Naturally aspirated stock 531 engine(pre 25000 serial #)with 4500hours on it and have had this tractor for 7 years and 2000hours..had it on a dyno 2 years ago and it peaked out at 136hp but guy running the dyno said it is accurate in, all honesty within plus/minus 5 Hp at the range (it was a 500hp max dyno), with a turbo on the 6030>> a little more boost (and fuel) goes a long way to more hp....
rjb
09-02-2004 09:53:28
 Re: JD 5020 Please HELP!! in reply to tipton, 09-02-2004 08:32:28
Thanks my friend...for the reply I am more or less looking to make sure that this is a RELIABLE machine more than anything else....How have you liked 5020 so far has it been any trouble?
tipton
09-07-2004 05:52:56
 Re: JD 5020 Please HELP!! in reply to rjb, 09-02-2004 09:53:28
at 4500 hours I am having throwout bearing problems other than that, in the last 7 years other than batteries/filters...i have had to replace steering cylinder seals (if they leak you start to loose turning radius), the plastic return lines that clip on each injector (the blew under full load on a hill side shortly after I got the tractor.. change them if they look yellow),I check the rod bearings every 1000hours as several guys in my area had problems in the past ..so far okay
I have had no problems with engine or trans (other than shifter linkage)brakes, hydraulics etc, etc. My son does custom work with this machine with a 17ft centerfold 220 JD disk in heavy clay in rolly terrain ...so this machine is loaded to all it wants to handle.....
JD 5020 guy
09-01-2004 21:22:32
The 6030 was way underated but I don"t know if JD did that with the 5020. The engine in the 5020 is not as "hot" as the one in the 6030. It kinda depends on the condition of the tractor too. In my experience, it seems like tractors loose a little hp when they start getting a lot of hours on them
rjb
09-02-2004 05:43:34
 Re: JD 5020 Please HELP!! in reply to JD 5020 guy, 09-01-2004 21:22:32
The tractor from the photos looks REAL CLEAN has 4325 hours on this machine...what would you advise..I specificly ask for the Dynomo test
buickanddeere
09-01-2004 20:49:02
I would rather have the dealer tell me it made 130HP than 150HP. Both for the tractors condition and the dealer"s honesty.
rjb
09-02-2004 05:48:03
 Re: JD 5020 Please HELP!! in reply to buickanddeere, 09-01-2004 20:49:02
Yes you have a very good point...the tractor only has 4325 hours on it...what do you think? It looks real clean!!
By the way he said it produced are the 130'ish range not just 130 HP...
Markie
09-01-2004 22:57:16
I'm a little bit in to the 6030-thing. So I read as much as I can find on them. The HP-ratings are from the original 175,99 to 225HP and up. I think that the rating depends on how the fuelpumpsrews are turned...and of course how good the engine still is...for example, bad fuel injectors cost lots of HP...I've seen pictures of 6030's with the 619 engine. These tractor produce a lot more horsepower that the originally 531 engine.
Hope this helps a bit..
Greetings Mark
09-02-2004 20:12:31
 Re: JD 5020 Please HELP!! in reply to Markie, 09-01-2004 22:57:16
The 6030 never came from the factory with a 619 though. Same block as the 531 thought.
