john deere a crankshaft question
rman
04-08-2004 20:28:45
we have a john deere a 1951 it has a bad knock in it when we bought it pulled cover to access crank found rod had been real loose on crank for long time egg shaped crank my question is we had a 60 that we parted out and saved crank and rods will this fit a and will everything interchange. thanks for any help mike
Mike
04-09-2004 22:50:12
 Re: john deere a crankshaft question in reply to rman, 04-08-2004 20:28:45
The rods will work, but the crank will not due to the live power gear setup for the 60, ps I have a crank that I'd sell.
ET
04-09-2004 09:18:33
The rods from a 60 will work ina late model A and the bearing inserts make it easy to grind the crankshaft undersize. The crankshafts will not interchange.
Mike in Louosiana
04-09-2004 07:01:42
I don't the answer, but need to know MODEL.
