4020 leaking hy. fluid
rob
03-28-2004 19:12:52
My 4020 just developed a leak that appears to be dripping from the area just in front of where the right 3 pt. arm attaches to the tractor is there a seal or anything there. It is a very small drip that just continues it was full htree days ago before the leak now it is dry and I have a large oil spot to clean. Thanks for any help.
JD68
03-29-2004 01:56:23
 Re: 4020 leaking hy. fluid in reply to rob, 03-28-2004 19:12:52
don't even consider using JD seals. use the aftermarket stuff from boling machine. I'v had a set in my 4020 for over 20 years and not drip from the rockshaft.
Bob
03-28-2004 19:40:44
That is a common leak point on those tractors. There is a "LOAD CONTROL SHAFT" that passes through from one side of the tractor to the other, and there is a seal at each side. All it takes is a little wear to the shaft, or the bushings, and they'll leak.
Sometimes, just replacing the seals is enough for a long time. There is an aftermarket outfit that makes improved seals. I can't think of the name at the moment, but I'm sure someone else will contribute that!
twopop
03-28-2004 20:18:04
 Re: Re: 4020 leaking hy. fluid in reply to Bob, 03-28-2004 19:40:44
www.bolingmachine.com
Bob
03-28-2004 20:57:27
 Re: Re: Re: 4020 leaking hy. fluid in reply to twopop, 03-28-2004 20:18:04
Ad hyphen to make Twopop's link work.
rob
03-29-2004 04:04:33
 Re: Re: Re: Re: 4020 leaking hy. fluid in reply to Bob, 03-28-2004 20:57:27
Thanks guys, the help is exactly why I love this sight.
