power trol wont hold disc up
rman
09-25-2003 20:38:48
went to disc today with 70 gas disc lift ok but will not stay up graduly lowers itself changed cyl. still does same thing what could be wrong
Clooney
09-26-2003 03:16:34
 Re: power trol wont hold disc up in reply to rman, 09-25-2003 20:38:48
Rman, almost anything from a cylinder ring still leaking to a cylinder base gasket leaking, to an internal valve leaking, to a P/T housing gasket problem….
~First thing to look for is if the Power-Trol is loosing oil..If so, you probably have a cylinder base gasket blown out.
~One thing to do is to raise the 3-point with a load on it, then back the throttle valve screw off [lower rear of P/T box with cap nut over it] until is doesn’t touch the throttle valve anymore then see if it will hold the load up…If so, your problem isn’t in the cylinder area or base gasket, if it still drops then you have a piston ring problem or base gasket problem..
JDClooney@aol.com
