Knockin A
Rman
08-20-2003 20:43:15
I have a J.D. A electric start that has a knock.. i put in a new clutch w/ plate and new disc's and flywheel is tight.. i pulled off the crank case plate on top and the rods seem to be tight on the crank .. has anyone else experienced this problem? where could the knock be coming from?? thanks for the help!
Clooney
08-21-2003 11:43:56
 Re: Knockin A in reply to Rman, 08-20-2003 20:43:15
Rman, that knock could be anything from a loose piston pin, to a worm piston, to a bearing, to ?
~Does the knock happen at all engine speeds? At all loads? At all engine temperatures? With the clutch in or out? In or out of gear? Does it get worse or better under any conditions? If so what are they?
~Is the knock occuring once per revolution? Or every other revolution?
~Does shorting either plug wire to ground change the noise?
~Remember we can't hear it so you will have to tell us all you can to get a good educated answer...
Walt in Jaxn Tn.
08-20-2003 21:03:31
Now is a good time to go down to the local auto parts store and buy a mechanics stethescope. they're cheap and have a lot of good uses around the house. I sometimes take the sound producer off the end of the hose and feed the hose into the crankcase a little to hear the inside of the crankcase while the engine runs. I've also used it to find water leaks in the water lines in my house like the valve in the comode. ther're good for listening to the bearings on either end of the fan shaft on the john deere A
