630 carb problem
rman
07-08-2003 20:20:59
we have 630 that wont idle without choke out about half removed carb complete cleaned blowed out passages used small wire in all holes thottle shaft doesnot seem to have much play butterflys are in good shape thanks for any advice
TIMAR
07-09-2003 19:07:46
 Re: 630 carb problem in reply to rman, 07-08-2003 20:20:59
Try replacing the screen in the sediment bowl. I had the same problem and had the carb apart 3 times. The screen in the bowl did not look dirty, but was scummed up.
Mel
07-08-2003 21:26:52
There are 2 little soft plugs on the sides of the carb that you have to remove and work a wire ( I use a gas torch cleaning wire) through. It'll idle if you get them clean. You can get the plugs from JD for less than a couple bucks each.
