J.D. H compression
Rman
06-05-2003 20:58:44
How much compression should a John Deere H have? and also what are the bolts on each side of the head for? thanks for the help!
Clooney
06-06-2003 02:18:14
 Re: J.D. H compression in reply to Rman, 06-05-2003 20:58:44
Rman, the compression kind of depends on the cranking speed. But the spec is 80 PSI. at cranking speed [hot engine, carb & choke wide open]..
~Those bolts aren't really bolts....They are bearings that hold the rocker arm shaft on each end where it passes through the cylinder head sides.
RMAN
06-06-2003 10:13:14
 Re: Re: J.D. H compression in reply to Clooney , 06-06-2003 02:18:14
THANK YOU FOR REPLEY R-MAN
