The lights work except when it runs...
rob-o
05-27-2003 14:32:31
This sounds crazy I know. But the lights work on my 1010 when you turn the key and flip the switch. But when the tractor is running, the lights don't work. What's up with that guys? Thanks for your help.
M Young
05-28-2003 09:07:37
 Re: the lights work except when it runs... in reply to rob-o, 05-27-2003 14:32:31
Hi. I am guessing there is a bad connection between the key switch and the light switch, possibly a bad/broken wire, even possibly a grounding problem. I have worked on electric vehicles for ten years and have seen some pretty freaky electrical problems, and electrical problems in my opinion are the worse(pain it the rear)breakdowns, Try the simple things first, battery corrosion,conections,and wire condition. I hope this helps. Mike
