JD 70-oils
Rob
05-26-2003 19:18:40
What oils should be used in the power trol, PTO
gear box, and transmission of an old JD 70? The owners manual says to use engine oil in the power
trol and called for non-detergent oil. The oils called for are not available anymore and I want to change all the fluids in this tractor with current
oils.
Mike S
05-27-2003 14:39:00
 Re: JD 70-oils in reply to Rob, 05-26-2003 19:18:40
I just got done rebuilding my 70 gas. I used 30W in the engine and power trol, in the pto I used JD hydratrans and 80-90W in the rear end. I know I should of used non-detergent in the power trol but I rebuilt it and couldnt see what it would hurt. The reason to use the same oil as in the engine is because if the power trol pump leaks it will just go in the engine. If you dont want to use detergent oil in the power trol just put in some 30W non-detergent in the power trol only.
